I am receiving this error when I try to run my code. Can anybody help me with fixing this? Also can somebody tell me what Maven is?
cd C:\Users\JCmobile\Documents\NetBeansProjects\CSE360; "JAVA_HOME=C:\\Program Files\\Java\\jdk1.7.0_71" cmd /c "\"\"C:\\Program Files\\NetBeans 8.0.1\\java\\maven\\bin\\mvn.bat\" -Dexec.args=\"-classpath %classpath cse360.soodooku.views.Main\" -Dexec.executable=\"C:\\Program Files\\Java\\jdk1.7.0_71\\bin\\java.exe\" -Dmaven.ext.class.path=\"C:\\Program Files\\NetBeans 8.0.1\\java\\maven-nblib\\netbeans-eventspy.jar\" -Dfile.encoding=UTF-8 org.codehaus.mojo:exec-maven-plugin:1.2.1:exec\""
Running NetBeans Compile On Save execution. Phase execution is skipped and output directories of dependency projects (with Compile on Save turned on) will be used instead of their jar artifacts.
Scanning for projects...
Building soodooku1 1.0-SNAPSHOT
--- exec-maven-plugin:1.2.1:exec (default-cli) @ soodooku1 ---
SLF4J: Failed to load class "org.slf4j.impl.StaticLoggerBinder".
SLF4J: Defaulting to no-operation (NOP) logger implementation
SLF4J: See http://www.slf4j.org/codes.html#StaticLoggerBinder for further details.
[EL Info]: 2014-11-13 15:33:49.544--ServerSession(2143138163)--EclipseLink, version: Eclipse Persistence Services - 2.5.2.v20140319-9ad6abd
[EL Severe]: ejb: 2014-11-13 15:33:50.2--ServerSession(2143138163)--Exception [EclipseLink-4002] (Eclipse Persistence Services - 2.5.2.v20140319-9ad6abd): org.eclipse.persistence.exceptions.DatabaseException
Internal Exception: java.sql.SQLException: Access denied for user 'root'@'localhost' (using password: YES)
Error Code: 1045
Exception in thread "main" javax.persistence.PersistenceException: Exception [EclipseLink-4002] (Eclipse Persistence Services - 2.5.2.v20140319-9ad6abd): org.eclipse.persistence.exceptions.DatabaseException
Error Code: 1045
at org.eclipse.persistence.internal.jpa.EntityManagerSetupImpl.deploy(EntityManagerSetupImpl.java:766)
at org.eclipse.persistence.internal.jpa.EntityManagerFactoryDelegate.getAbstractSession(EntityManagerFactoryDelegate.java:204)
at org.eclipse.persistence.internal.jpa.EntityManagerFactoryDelegate.createEntityManagerImpl(EntityManagerFactoryDelegate.java:304)
at org.eclipse.persistence.internal.jpa.EntityManagerFactoryImpl.createEntityManagerImpl(EntityManagerFactoryImpl.java:336)
at org.eclipse.persistence.internal.jpa.EntityManagerFactoryImpl.createEntityManager(EntityManagerFactoryImpl.java:302)
at cse360.soodooku.controllers.SoodookuController.<init>(SoodookuController.java:28)
at cse360.soodooku.views.Menu.<init>(Menu.java:67)
at cse360.soodooku.views.Main.main(Main.java:14)
Caused by: Exception [EclipseLink-4002] (Eclipse Persistence Services - 2.5.2.v20140319-9ad6abd): org.eclipse.persistence.exceptions.DatabaseException
Error Code: 1045
at org.eclipse.persistence.exceptions.DatabaseException.sqlException(DatabaseException.java:331)
at org.eclipse.persistence.exceptions.DatabaseException.sqlException(DatabaseException.java:326)
at org.eclipse.persistence.sessions.DefaultConnector.connect(DefaultConnector.java:138)
at org.eclipse.persistence.sessions.DatasourceLogin.connectToDatasource(DatasourceLogin.java:162)
at org.eclipse.persistence.internal.sessions.DatabaseSessionImpl.setOrDetectDatasource(DatabaseSessionImpl.java:204)
at org.eclipse.persistence.internal.sessions.DatabaseSessionImpl.loginAndDetectDatasource(DatabaseSessionImpl.java:741)
at org.eclipse.persistence.internal.jpa.EntityManagerFactoryProvider.login(EntityManagerFactoryProvider.java:239)
at org.eclipse.persistence.internal.jpa.EntityManagerSetupImpl.deploy(EntityManagerSetupImpl.java:685)
... 7 more
Caused by: java.sql.SQLException: Access denied for user 'root'@'localhost' (using password: YES)
at com.mysql.jdbc.SQLError.createSQLException(SQLError.java:996)
at com.mysql.jdbc.MysqlIO.checkErrorPacket(MysqlIO.java:3887)
at com.mysql.jdbc.MysqlIO.checkErrorPacket(MysqlIO.java:3823)
at com.mysql.jdbc.MysqlIO.checkErrorPacket(MysqlIO.java:870)
at com.mysql.jdbc.MysqlIO.proceedHandshakeWithPluggableAuthentication(MysqlIO.java:1659)
at com.mysql.jdbc.MysqlIO.doHandshake(MysqlIO.java:1206)
at com.mysql.jdbc.ConnectionImpl.coreConnect(ConnectionImpl.java:2234)
at com.mysql.jdbc.ConnectionImpl.connectOneTryOnly(ConnectionImpl.java:2265)
at com.mysql.jdbc.ConnectionImpl.createNewIO(ConnectionImpl.java:2064)
at com.mysql.jdbc.ConnectionImpl.<init>(ConnectionImpl.java:790)
at com.mysql.jdbc.JDBC4Connection.<init>(JDBC4Connection.java:44)
at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
at sun.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:57)
at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:45)
at java.lang.reflect.Constructor.newInstance(Constructor.java:526)
at com.mysql.jdbc.Util.handleNewInstance(Util.java:377)
at com.mysql.jdbc.ConnectionImpl.getInstance(ConnectionImpl.java:395)
at com.mysql.jdbc.NonRegisteringDriver.connect(NonRegisteringDriver.java:325)
at java.sql.DriverManager.getConnection(DriverManager.java:571)
at java.sql.DriverManager.getConnection(DriverManager.java:187)
at org.eclipse.persistence.sessions.DefaultConnector.connect(DefaultConnector.java:98)
... 12 more
BUILD FAILURE
Total time: 8.281s
Finished at: Thu Nov 13 15:33:50 MST 2014
Final Memory: 4M/123M
Failed to execute goal org.codehaus.mojo:exec-maven-plugin:1.2.1:exec (default-cli) on project soodooku1: Command execution failed. Process exited with an error: 1 (Exit value: 1) -> [Help 1]
To see the full stack trace of the errors, re-run Maven with the -e switch.
Re-run Maven using the -X switch to enable full debug logging.
For more information about the errors and possible solutions, please read the following articles:
[Help 1] http://cwiki.apache.org/confluence/display/MAVEN/MojoExecutionException
Error Code: 1045
Error Code: 1045
Error Code: 1045
... 7 more
... 12 more
BUILD FAILURE
Total time: 8.281s
