I have Seasonic X650 power supply and I need longer modular PSU to CPU 8pin cable than the provided 60cm (2ft). I tested the original cable and the results are in the image below. Do you need to connect the ground pins exactly as they are or can you make straight parallel connections, which would result in a neater sleeved cable?
I was told that pins 5 through 8 could be wired with a single wire, joint at the connectors. Is that untrue or just unadvisable to avoid overload? Are any of the other pins combinable to a single conductor? I will be using high quality silver coated AWG16 copper conductor, which should be able to withstand a good 20 amps or even more and the new cable length will be 140cm (4.6feet). I sent these questions directly to Seasonic, but you never can say if there's any replies to be had to these types of enquiries and if there is it's fairly common they are in a disclaimer form "don't do it".
