I don't have any dimensions for these new SFX power supplies, but either way I can increase one dimension or another to allow them to fit. If they are only longer then more than likely they will fit the M3A2 as is. If they are wider than I only need to increase the depth of the case accordingly.Yeah, I have read of lots of people in this forum complaining about the noise on the SFX PSU from Silverstone, but because of the differentiated dimension on the High Power SFX PSU I was worried it might not even fit in the case CMadki4 is designing.
Could you please explain me, or give me a link where I could learn the difference between compatible and optimized PSU for haswell? I couldn't quite find it on google and I plan to soon get a haswell based build too, so. (a list of the optimized ones would also be apreciated )
