Skipper007
- Jun 28, 2004
I'm really tired of having to back stuff up to DVD-R and I don't trust a single drive with my data, so I want to build an eSATA system that allows me to backup data to two external drives. Here's what I'm thinking:
One Syba dual port eSATA controller (Sil 3132 chipset)
One Western Digital Caviar Green 2TB (EARS version)
One Seagate Barracuda LP 2TB (I figure that using different models reduces the chances of simultaneous failure)
Four Rosewill RX35-AT-SC eSATA/USB 2.0 enclosures (two to use plus another two I can use when I need another set of 2TB drives... these enclosures are cheap.)
Total: about $360 Canadian including taxes and shipping.
Now, since all the enclosures will be the same model, I should be able to use their AC adaptors interchangeably, right? In that case, I'll tape two AC cables and two eSATA cables up to my desk (poor man's drive dock...), allowing me to have two drives hooked up at once. The third AC and data cable set will be installed on my brother's desk (since he sometimes needs access to my stuff), while the fourth will be used as my "to go" set. The two drives (and the next pair when I need them) will be swapped between these setups.
I figure that using "green" drives is best here, since I won't be using these for applications where random access is important and I believe the Rosewills are passively cooled enclosures (I'd prefer to avoid active cooling since in my experience small fans tend to fail pretty easily).
Concerns:
-Since these drives will be off most of the time, I'm worried about being able to do a "burn in" test on them.
-I'm also not sure how to run S.M.A.R.T. tests on external drives.
-Am I making a mistake going eSATA when USB 3.0 is coming out? I suppose I can just move the Syba card to my next PC, since I'm the only one who is going to be using the drives frequently.
-Am I going to be able to tell the drives apart in the "safely remove hardware" menu if I have two eSATA drives hooked up at once?
Any feedback would be great!
Concerns:
