Happy Hopping
- Jul 1, 2004
how often does this happen on your day to day use of this screen?
I use a lot of dcc software, Maya nd Fusion in particular. This issue shows up in both. They both have fairly neutral dark gray interfaces. In fusion, the viewport will streak over into the grey GUI, living a distinct pinkish band. It gives me the irritsIn what uses do you find it distracting?
I thought it might be broken, I didn't even know this was a thing, I guess I was too used to IPS panels.
I did two tonight.
Is the Apple model A1316? I want to make sure, although I see only one Apple Cinema Display 27" model.
Where did you get the info on the Monoprice being AUO? Their spec page calls it "AH-IPS" which should mean some LG panel, but so far all LG IPS panels didn't have the problem.
Enjoy the stunning beauty of an Advanced Hyper Viewing Angle display panel with this 27" Pro AHVA LED Monitor from Monoprice!
This 16:9 display panel uses the latest AHVA panel from AUO, which is capable of a maximum resolution of 2560x1440 and 10-bit color support for over 1 billion color variations. It features Dual Link DVI-D, HDMI®, VGA, and DisplayPort (version 1.2) video inputs.
It supports stereo audio input, as well as audio from the HDMI connection, and includes a pair of 2-watt speakers. It boasts an ultra-wide 178° viewing angle in both the horizontal and vertical planes and a 0.2331mm pixel size. It includes a removable stand and has a 100x100 VESA mounting size for use with desk or wall mounts.
Features:
27" AHVA monitor with LED backlighting
16:9 aspect ratio
2560 x 1440 @ 60Hz maximum resolution
1 DisplayPort input
1 HDMI input
1 Dual Link DVI-D input
1 VGA input
Detachable stand allows for tilt and swivel, plus rotation for easy portrait/landscape orientation changes
Built-in stereo speakers with 2 watts/channel amplifier
100 x 100 VESA mounting pattern
Maybe they used two panel types in the same model. AHVA indeed seems more likely because there were already such panels reported, unlike LG ones. But then munkle said:It's been discontinued, and I don't know why that spec page/PDF lists that. Here's the archived page for it:
https://web.archive.org/web/20150919220057/http://www.monoprice.com/product?p_id=12520
That's unexpected. It uses an LG panel that is a close relative of the one in the U3011, which doesn't exhibit the artifacts. Both are also Dell monitors. The plot thickens.Dell 3008wfp has issues.
Daniel_Chang, can you try to see with HWINFO32 which specific panel the Monoprice uses? Choosing your display under "Monitor" shows in the details pane "Monitor Name (Manuf)", which at least on laptops tends to show the panel model. But I'm not sure if it works for standalone monitors.
HWiNFO32 Version 5.10-2700
DESKTOP---------------------------------------------------------------
[Current Computer]
[Operating System]
Monitor -------------------------------------------------------------------
Unknown -------------------------------------------------------------------
[General information]
Monitor Name: Unknown
Monitor Name (Manuf): MPLE27QPM-R2
Serial Number: MSA141200001
Date Of Manufacture: Week: 50, Year: 2014
Monitor Hardware ID: Monitor\MPC2700
Max. Vertical Size: 34 cm
Max. Horizontal Size: 60 cm
Horizontal Frequency: 15 - 99 kHz
Vertical Frequency: 23 - 76 Hz
Maximum Pixel Clock: 250 MHz
[Advanced parameters]
Input Signal: Digital
Display Type: Unknown
Gamma Factor: 2.20
[DPMS Modes]
Standby: Not Supported
Suspend: Not Supported
Active Off: Supported
Standard Colour Space: Not Supported
Preferred Timing Mode: Supported
Default GTF Supported: Not Supported
DFP 1.x Compatible: No
[Supported Video Modes]
1152 x 864 75 Hz
1280 x 720 60 Hz
1280 x 1024 60 Hz
1440 x 900 60 Hz
1680 x 1050 60 Hz
1920 x 1080 60 Hz
2560 x 1440 597 x 336 mm, Pixel Clock 241.50 MHz
Monitor
Model name............... MPLE27QPM-R2
Manufacturer............. MPC
Plug and Play ID......... MPC2700
Serial number............ MSA141200001
Manufacture date......... 2014, ISO week 50
Filter driver............ None
EDID revision............ 1.3
Input signal type........ Digital
Color bit depth.......... Undefined
Display type............. Undefined
Screen size.............. 600 x 340 mm (27.2 in)
Power management......... Active off/sleep
Extension blocs.......... None
DDC/CI................... Supported
MCCS revison............. 2.1
Display technology....... TFT
Controller............... Mstar
Firmware revision........ 1.0
Firmware flags........... 0x0000005A
Active power on time..... Not supported
Power consumption........ Not supported
Current frequency........ 88.90kHz, 60.00Hz
Color characteristics
Default color space...... Non-sRGB
Display gamma............ 2.20
Red chromaticity......... Rx 0.660 - Ry 0.332
Green chromaticity....... Gx 0.300 - Gy 0.629
Blue chromaticity........ Bx 0.147 - By 0.052
White point (default).... Wx 0.313 - Wy 0.329
Additional descriptors... None
Timing characteristics
Horizontal scan range.... 15-99kHz
Vertical scan range...... 23-76Hz
Video bandwidth.......... 250MHz
CVT standard............. Not supported
GTF standard............. Not supported
Preferred timing......... Yes
Native/preferred timing.. 2560x1440p at 60Hz (16:9)
Modeline............... "2560x1440" 241.500 2560 2608 2640 2720 1440 1443 1448 1481 +hsync +vsync
Standard timings supported
720 x 400p at 70Hz - IBM VGA
640 x 480p at 60Hz - IBM VGA
640 x 480p at 75Hz - VESA
800 x 600p at 60Hz - VESA
800 x 600p at 72Hz - VESA
800 x 600p at 75Hz - VESA
1024 x 768p at 60Hz - VESA
1024 x 768p at 75Hz - VESA
1280 x 1024p at 75Hz - VESA
1152 x 864p at 75Hz - VESA STD
1280 x 720p at 60Hz - VESA STD
1280 x 1024p at 60Hz - VESA STD
1440 x 900p at 60Hz - VESA STD
1680 x 1050p at 60Hz - VESA STD
1920 x 1080p at 60Hz - VESA STD
Report information
Date generated........... 1/6/2016
Software revision........ 2.90.0.1002
Data source.............. Real-time 0x0011
Operating system......... 10.0.10586.2
Raw data
00,FF,FF,FF,FF,FF,FF,00,36,03,00,27,01,01,01,01,32,18,01,03,80,3C,22,78,3A,0C,D5,A9,55,4C,A1,25,
0D,50,54,A5,CB,00,71,4F,81,C0,81,80,95,00,B3,00,D1,C0,01,01,01,01,56,5E,00,A0,A0,A0,29,50,30,20,
35,00,55,50,21,00,00,1E,00,00,00,FF,00,4D,53,41,31,34,31,32,30,30,30,30,31,0A,00,00,00,FD,00,17,
4C,0F,63,19,00,0A,20,20,20,20,20,20,00,00,00,FC,00,4D,50,4C,45,32,37,51,50,4D,2D,52,32,0A,00,C9
I'll count that as positive.SE39UY04 has issues only if the image is displayed over a gray background. No issues if the background is white or black.
Monoprice 12520 (MPLE27QPM-R2) 27" ? AHVA? AUO? (might be LG AH-IPS)
Apple Cinema A1316 27" 2009? H-IPS LG LM270WQ1-?
Yes, it appears to be the same display found in the iMac Intel 27" from October of 2009, as well as the same basic LG display found in Dell's competing 27" monitor, though the Apple version uses LED backlights as opposed to Dell's traditional CCFL.
BTW, funny inputs on these monitors. 2 HDMI but no DP, VGA instead of DVI.
How pronounced does the discoloration/streaking look with HDMI?
Does a white grid look any different between HDMI and VGA?
Whatever panel is in my old Dell Precision m4500 does not have any issues displaying the second picture in the OP. It is the 1920x1080 monitor.
