Stupid_Newbie
- Dec 4, 2005
Looking to build a PC for the kids, to keep them off mine and out if the office.
1) What will you be doing with this PC? Light Gaming, Flash Games, YouTube etc
2) What's your budget? No budget restrictions
3) Which country do you live in? Canada, Alberta. Most likely Newegg.ca, NCIX, etc
4) What exact parts do you need for that budget? Case, PSU, Mobo, Ram, CPU, Cooler, Bluray drive, keyboard, mouse.
5) If reusing any parts, what parts will you be reusing?
-?256GB Crucial M4 (sitting around, as I now have a Crucial 500)
Anything from current rig really, though not planning on it.
6) Will you be overclocking? No
7) What is the max resolution of your monitor? Either my current 23x1920x1080, or something in the 24-27 area.
8) When do you plan on building/buying the PC? Anytime now.
9) What features do you need in a motherboard? Onboard audio, USB3, gigabit Lan.
10) Do you already have a legit and reusable/transferable OS key/license? If yes, what OS? Is it 32bit or 64bit? No
I'd like to have something similar to my Raven 2 Evo. It's big, but cools well, and is honestly near silent (when GPU isn't maxed out and heavily OCed.
I will be putting a big cooler in regardless (like my NH-D14) just to keep it quiet. This will be in the corner of my rec room, so quiet is top notch in my books.
