RangerXML
- Apr 16, 2006
Chrome initially had its issues to with a ModernUI launch, namely no way to control which one you launched into, desktop or modernUI, but later they added a nice toggle. I got the email offer today to upgrade from TMT5 to 6 for $10, I mistakenly took it. There is no control, I can't figure out how to get back to the desktop mode, the support shortcuts aren't working right and take you to the TMT5 support page.
Now here is the interesting bit, when I first launched TMT6 it started in a desktop mode, I had started it from the desktop. I activated it and enabled hardware acceleration, closed it down, went to the start screen and launched it from there to see the modernUI version. Nerfed does not even begin to describe it, go to the settings menu its about as dumbed down as it gets, more then half the options are missing and all your left with are a couple of check boxes and toggles. Next thing you'll notice, its not even a real modernUI interface, just a dressed up full screen desktop window, none of the modernUI gestures work including the charms and app switching (sucks to be on a tablet).
I wanted to play with the 2D to 3D conversion since its one of its main selling points (the nice ad bulletin points) so I load up a MKV I made from Star Trek (2009) and it about gives me a headache with no 3D effect. Also tried some of my BDs and DVDs, no difference, some wouldn't even start the faux 3D. So I wanna see if I can play with the settings a bit, but the settings are missing via the modernUI, no problem switch back to desktop mode...how? I try to quit the program and starting it from the desktop shortcut, it sends me back to the faux modernUI. After digging around the program directory I find nothing. So this is where my fun with the support section begins, but I've already talked about that, TMT5. Now admittedly the desktop mode worked just like TMT5, but I have no way of getting to it.
I haven't tried rebooting and trying to launch it from the desktop, that is how I resolved the issue when Chrome initially took away the ability to determine which mode you go into via where you launch it from with out mentioning that they just added a switch. I tried googling to see if anyone else had any experience with it yet only to find that since its about 2 weeks old not very many outside the warez community have even touched it (I bought TMT5 and bought the upgrade to TMT6). I'm probably installing TMT5 again until they fix some of this up a bit.
