Furious_Styles
- Jan 16, 2013
Yeah it's just one of those things you don't consider immediately, like the power button someone mentioned earlier in the thread. Working with risers myself now I definitely test them, a simple mistake is having PCI-e gen 4 when the riser only is gen 3 and thus no display working until you change it in the bios.I’ve never used a test bench but I agree I may not have first thought of the riser if it was supplied with the case. But it would have been on my short list of things. I think OP could trouble shoot in the future and is probably learning from all this. I’ve not had good luck with riser cables.
I have had good luck with rigid pcie riser adapters like you see in the Fractal Ridge. The Terra also has a very high quality ribbon riser but even fractal has done a recall to both of those in the past.
