Clockworks
- Aug 23, 2004
My last TV Tuner card was a Hauppauge 150MCE. Now, I wouldn't be coming here for help if it wasn't for the fact that once I upgrade my Vista machine to 6GB of RAM, the card refuses to work. Found out it was something to do with the PCI slot, 4GB+, and Hauppauge's general fail. Awesome.
- With that said, what's a good card in the $100 range (less would be good too)? I'm seeing a bunch of digital tuners, which is fine but I have no idea how they work.
- Can I hook up traditional cable and/or have OTA digital signal picked up?
- Will it also work with more than 4GB+ of RAM under Vista/Windows 7 64-bit?
- PCI-e or USB, whatever you think is best?
- Can I hook up a PS2 or another console to it now or will there still be a lag like the 150MCE?
