Hello all,
I have been following the situation with the 30" monitors for about a month and I have to say that I finally have narrowed down my options down to 2 choices:
A) Buy the HP 30" (I can't be bothered to wait for the Dell 3 more months and I understand that it might not be that different.
B) A 37" HDTV (the Westy is not available in my country Greece but we have other nice equivalents (Sharp Aquos, Amoi).
I really love big size and I am almost ready to go for the 37" however I would like your views on that since it will be my main PC monitor too. If I buy the 37" I can keep it for some months and then it can serve me as a TV in another room (bedroom) that I need a TV for and change for the Dell then.
For those with the Westinghouse displays; do you find the 1920x1080p resolution enough for desktop use? I mainly use my PC with Excel, Word, Outlook, and internet. Then I might open (not work on) the occasional Autocad drawing and then its games, music. I DO NOT watch movies on my PC (hehe I love my huge sofa).
My PC is [email protected], 2x 8800GTX SLI
So what would you go for? My only concern is if 1920x1080 is enough at a 37" screen. I am using a 22" (20) Diamontron CRT - Gateway VX1120 now.
