HyperX: HX316C9SRK2/16 or HX318C9SRK2/16
elodman
Greets
which 2x8 GB RAM is better / quicker for a Z-97, i3-4170 (and future i5, .. upgrades)?
" Each module
has been tested to run at DDR3-1600 at a low latency timing of
9-9-9 at 1.5V.
The SPDs are programmed to JEDEC
standard latency DDR3-1600 timing of 11-11-11 at 1.5V. "
source: http://www.kingston.com/datasheets/HX316C9SRK2_16.pdf
"Each module
has been tested to run at DDR3-1866 at a low latency timing of
9-10-11 at 1.5V.
from: http://www.kingston.com/dataSheets/HX318C9SRK2_16.pdf
(No hardcore overclocking planned, - i don't wanna damage / shorten life of any component ... yet)
thanx
If same price, buy HX318C9SRK2/16
They will run at 1600 CL9 @ 1.5v
But at different prices, the performance difference is negligible and you should go with the cheaper option.
