you dont need more than 4 cores for gaming. clock speed is needed more
BD is almost here. I would wait for that to come out and have it drop the prices on the Phenom II line personally. Let the 1090T drop like a rock and pick up one of those.
I would highly recommend you look at the 955 or 965 instead for gaming. The 955 is only $112 w/ free shipping via Amazon and a straight forward overclock without worrying about RAM dividers.
http://forums.overclockersclub.com/index.php?showtopic=175015
There are 1035T's that overclock as well as the 1055T but I wouldn't personally count on it and with the 13x multiplier you may you run into your motherboard's HT reference clock ceiling before the chip's clock ceiling.
How is a 1035t for gaming and general use at stock speeds. What kind of OC should I expect to get with one?
Overclock it and it is AWESOME! It has a decent multiplier (13X) and most boards can do 233 on the "fsb" so it'll run to at least 1075t speeds (3.0Ghz), and it's great at those speeds. Now, I have gotten up to 250 on the "FSB" on many of my AM3 chips. So you may have the potential of getting 3.2Ghz...and the high HTT and corresponding ram speeds will give you very nice performance. Also I believe it would also turbo up (you may be able to set this in the bios depending on your board) to 3.6Ghz. I have mine set to turbo 4 cores to 4.2Ghz (AMD Overdrive is great for this, you can get it at amd's site). I'm very happy with this cpu at stock and my overclock is the cherry on top.
Overall, I think it's a great deal. I considered this to upgrade my #3 machine.
that a nice price for a new 1090t cruisd64.
It doesn't:
I just upgraded one of my secondary machines from a Kuma 7750 -> 1035t. I got 3.2 @ 250fsb out of mine and Im only using a ultima 90 with dual 120mm's I got it on sale at new egg for $120. yes the Black editions could clock higher but for over 50 bucks more.
Zarathustra[H];1037770936 said:Could be because these benches use an older 5870, and are running at 1920x1200. They may be too GPU limited to show a difference.
Can't you push mobo a bit more ? Or mess a it with turbo modes in AMD overdrive tool?
I haven't put too much effort into this so far just a preliminary run at this point. I am new to turbo mode so while i have messed with overdrive before i dont know how to monkey with the turbo mode. I am behind the times in the ocing world i guess using bios to overclock fsb/htt is out of style.
