ntherblast
- Jan 28, 2011
Hey all so it seems that the current drivers i'm using is corrupted or something because I am getting bsod and in the bugcheck it pointed to the nvlddmkm.sys not working. My card is a 570 gtx with 266.58 driver currently installed. Should I just install the new drivers over the old ones? Or should I uninstall in safe mode using device manager then use another software like driver sweeper to remove leftovers? Lastly should I uninstall everything like 3d, physics and high def?
