Good to go if you don't plan on overclocking much.
Don't these cards pull 300 watts under load? Thats 600 watts in cards alone.
I agree, 760w seems borderline to me on a 1366 rig.
Just because it runs doesn't mean you PSU is powerful enough, PSUs can and will pull much more wattage then they are rated for, I have seen a 500W PSU power a 800W rig for a few months before blowing and taking all the components with it.
Just because it works doesn't mean it is a good idea.
You have a point. I was thinking that since the MC deal right now on the 4770k I might just buy that and the 290s and have fun with it until I see a deal on a good PSU so thats why I asked. But if I need it now I dont mind buying a new one.
If running at stock.. then a quality 750W is fine.
Im running a 1100T with a H100 and a 290 + 290X with 6 HDDs (2 platter, 4 SSD) 32GB ram and no issues at all at defaults on Corsair 750W.
yeah no kidding and massive waste of gpu power and money.1100t would bottleneck the crap out of 1 card let alone 2. Of course your psu is fine when your only getting half the usage out of each at the best of times.
It is a good PSU. Unless you happen to be one of unlucky ones with a defective model:I thought the G2 was pretty good seeing as how Johnny Guru gave it a great review.
http://www.techpowerup.com/195102/evga-recalls-bad-batches-of-supernova-psus.html
Might want to check to see if your G2 is one of the affected serial numbers.
Check the BIOS versions on each card, if one has a newer one then flash that tot he other, if not then just pick one to flash to the other. Cards work better if they have BIOSs from the same manufacturer.
As all 290X are currently reference they can be flashed to any bios.
Over the rating for VA I presume. How much is it loaded up, and what rating is it?
Hmm flashed my Power Color Rom to my XFX and now I know for sure its not running correctly.
you are getting a low unigine score because you are not running it fullscreen. your 2nd card will not work running it in windowed mode . I get almsot 2600pts with my oced 290's in crossfire in heaven benchmark on all highest settings at 1920x1200res and full screen.
Didnt realize it made a difference. I switched the cards around now my XFX is in my first PCI-E lane and the Powercolor in the second. Its exhibiting the same thing. My second card gets no activity in BF4. I dont know why.
did you make sure all connection are secure to and from the psu and cards?
also, did you check what pcie slot you are supposed to use? you are using pci 3.0 at 8x or 16x each? some slots will only do 4x or 2.x, so you need to check your mobo manual as to which slot is which. make sure crossfire in active in CCC, even though my cards automatically activated. your not using a crossfire bridge right (I don't even know if it is possible wit these cards).?
Yep, always has been the case IIRC. People never understand why I don't run games in fullscreen-windowed and choose to moan about alt-tab delays
