Red Squirrel
- Nov 29, 2009
I have two spare Unifi APs that I'll probably put in service somewhere else so figured I would update the firmeware ahead of time. Problem is when I run the update it just says "+exec" and then it dies. I have no idea if it actually did anything and I can't seem to find anything on google about how to check the version. The update bin file does get deleted from tmp so I presume it worked... but I'd like to actually confirm.
As a side note, I was going to check my controller to see if it shows up on it (I don't want to actually adopt it but figured it might show version) but while I was in there I noticed that my in-service AP is showing as disconnected. Everything I try does not fix this. The AP itself actually does work fine. Is there a way to get it to actually show up properly? Both the AP and controller are on the same vlan and port 8443 is open in the firewall.
