Home File/Backup Server, ability to transcode video files while serving them using ps3 media server. Run several python based services, torrent client etc. and potentially more as I mess around with everything
Not sure at this point thinking $300-500, flexible
Denver, CO (near microcenter)
4) What exact parts do you need for that budget?
CPU, RAM, Case, PSU, Mobo, Perhaps a quiet cpu cooler (build needs to be quiet)
3 HDD that i have on hand, 2TB each, An 80GB intel ssd that I have for the OS (I don't want to run from a usb drive)
6) Will you be overclocking?
Nope
Headless server, would like integrated graphics for easier troubleshooting
This next weekend or the weekend after
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? UEFI? etc.
At least 6 Sata (3Gb/s or 6Gb/s doesn't matter) ports 7 or more would be nice, USB 3 would be nice but not required, Onboard Video (again for troubleshooting).
Yes, will be using centOS or Ubuntu Server (most likely the latter) and 64bit but obviously can easily change to 32bit
Would like to keep everything small and silent while still having the power to run everything I need.
Mainly trying to figure out what would be a good processor/mobo combo. PSU requirements and such all while keeping it reasonable price. Which i figure should be fairly easy since I have the 3 hard drives already.
Thanks for the help,
Cheers
Nope
Cheers
