Hello,
I've been getting multiple BSODs which happen in a seemingly random order, and they've gotten frequent in the past week. I've searched them and checked the sticky but am looking for more detailed information that I may not understand from the codes.
SYSTEM_SERVICE_EXCEPTION
STOP: 0x0000003B (0x00000000C0000005, 0xFFFFF80002C92EC1, 0xFFFFF88002BE9950, 0x0000000000000000)
and
KERNEL_DATA_INPAGE_ERROR
STOP: 0x0000007A (0xFFFFF6FC40006500, 0xFFFFFFFFC0000185, 0x00000000A26ED860, 0xFFFFF88000CA0008)
PSHED.dll - Address FFFFF88000CA0008 base at FFFFF88000C96000, Datestamp 4a5be027
and last, but not least
A clock interrupt was not received on a secondary processor within the allocated time interval.
STOP: 0x00000101 (0x0000000000000031, 0x0000000000000000, 0xFFFFF88002F63180, 0x0000000000000002)
I'm suspecting either the motherboard or the hard drive, but not sure which one is more likely to blame, the clock interrupt makes me want to point to the mobo, but the HDD (or mobo HDD controller) seem to be the culprit. In the "Event Viewer" I see alot of errors in "System" relation to the "disk controller," so I'm not sure if that's mobo-side or HDD. Going to try an install on a spare hard drive for the time being to see if I can replicate a BSOD.
Also, every once in awhile during boot I'll get a "Disk Read Error, press Ctrl+Alt+Delete to restart," and I simply have to turn it off for a minute or two, and the next time it will boot fine. I've also noticed freezes occurring after I notice the HDD indicator LEDs go blank, insinuating that the HDD is not being read or it has spun-down.
I'm puzzled, and thank you in advance for any help!
Inferno
and
Inferno
