P95 large ffts for 1 hour 10 min, Real Temp GT 3.70, Cpuid hardware monitor. i7-3930k @ 4200MHz, 1.33vdc, 16Gb Kingston HyperX @ 2139MHz on Asus R4F. NH-D14 after 1 Hour. RT GT 176f,167f,165f,162f,167f,167f. Cpu HM power 193.04W, 80C(176f) fans at 1254rpm & 1314rpm. The HE-01 is a radiator & 1/2 compared to the D14. It has 1 fan so I got a 120mm x 16mm fan - http://www.performance-pcs.com/cata...duct_info&cPath=36_1130_408&products_id=36185. The D14 & HE-01 were mounted blowing up. D14 in pull/pull, HE01 in push/push using Phobya HE grease as TIM. The HE-01 large rad on top leaves enough space over video card for the 120mm 1/2 fan under the small radiator. RT GT 169f,162f,160f,156f,165f,162f. Cpu HM power 190.51W, 77C (170f) fans at 2067 rpm & 1551 rpm. Now at those fan settings the HE-01 wins but it is much noisier than the D14. So I dialed the fans down to 1510 rpm & 1145 rpm. At those rpms it sounds like the D14. I continued running P95 at those rpms for 1/2 hour & RT GT was 174f,167f,165f,162f,169f,169f max. Cpu HM was 192.75W, 80C (176f) So about a tie at the same noise level. That's F'in amazing I didn't think anything but water could beat the D14. I even tried the Alpephon K2 aka. Deepcool Asssassin which lost by 5C to the D14 using the D14 fans. The K2 mounting sucks & the 120mm fan moves very little air, the 140mm moves about as much air as the D14 140mm.
