Uh the guy had both the cards while you dont. if you cant imagine doesnt mean it isnt true =(
And everything you read on the internet is true, including this statement.
I hope every post Blkout has ever made is deleted because its all garbage. I know im not the only one out there with this opinion and anybody that does go in and delete these please read into the garbage he says it does not belong on these forums its useless.
Enough of the name calling......if you cant converse in an adult manner, don't post
(1) Absolutely NO FLAMING, NAME CALLING OR PERSONAL ATTACKS. Mutual respect and civilized conversation is the required norm.
Just spoke to Newegg and am RMAing my card. Tried to run Heaven and it crashed the driver. Left a one star review on newegg, then went back and read some of the other reviews. As of today, an ASUS rep is commenting on the negative feedback comments with the following message:
Please try the new, updated GPU Tweak as it should help you run your GTX 670 better. You can download the new version from the Asus website here: www.asus.com/Graphics_Cards/NVIDIA_Series/GTX670DC2T2GD5/#download
I apologize for any inconvenience you may have had earlier. If you run into any problems after trying the new version, please contact me at *********@asus.com
When I get home from work and class, I may try installing the new version of GPU tweak, but I haven't had it installed at all in a few days as I get RSOD whenever it was running for the six hours I had it installed. I can't imagine that a new versin of GPU Tweak would bring stability to a card that's crashing anyway. I'm not going to downclock the card to get it stable when I paid extra for the higher clock.
Don't get me wrong, it would be the best deal on a 670 out there with the metal heat shroud, its great looks, the included backplate, and the higher clock.....if it worked consistently across cards.
Yeah, there's no way GPU Tweak is the issue with alot of these problems. MAYBE the red screen was GPU Tweak, as they apparently fixed an actual software bug (or so that rep claims), but crashes that aren't the red screen, and when you don't have GPU Tweak installed at all are simply an unstable card at stock clocks.
If the rep replies back to you with a reference number on your NewEgg review, you may still want to directly email him with the reference number even if you're doing the RMA via Newegg. That way you can emphasize that, no, GPU Tweak is not the issue and the chips are not being binned and/or QA'd properly.
Even though I've got a working card, I can understand how frustrating it is, and I'm certainly not buying another Top 670 for future SLI until these issues get ironed out.
I got the non-TOP for all the above reasons. Using Afterburner...
Decided to test my card a bit further and Heaven ran just fine for ~7 hours. Boost clock during this run was 1241 and my temp capped at 74. (Fan was on auto and running @45%)
It's a shame that some people are having issues with this model. I'm coming from a GTX580 (MSI Lightning)- and this new card is definitely quieter. (Though it runs a tad bit warmer, like 4-5 degrees.)
Starrbuck said:If you got over 70C the boost was limiting itself. You may want to do a custom fan profile to make it go above 45% to see if you can keep the card below 70C, then you might see a higher boost.
What were you able to push your non-top to?
Okay so Asus just commented on my review on Newegg of my Top 670 and said "try the new Asus GPU tweak utility update, it should fix your problems". I emailed the guy who wrote that and asked is he saying it will fix the red screen problem (which i assume it would), AND the driver failure, White screens, etc? And basically he emailed back hes not up high on the Asus ladder, and that its not official or anything, but he assumes yes. Now from my understanding...hes wrong right? Its not Asus GPU Tweak, its the card itself being OC'ed to high that it is unstable correct?
Hope you enjoy your cards! I'm currently debating on if I should get another to give it another chance. It was just SO quiet. I could probably scrape up the dough for a DC2 TOP 680, but I'm not sure if they are more stable or not... Since this is my second 670 in a row to have problems, I'm a bit wary about buying another.
I'm not sure hot asus tested this, did they just check which cards will run at 1137? and didnt factor in the boost ?_?
