CanesVenetici
- Jul 19, 2007
So I think I'm having ram issues. I threw my new system together in a bit of a hurry when my old system died.
Asus Maximus X Formula
8700k
Gskill TridentZ RGB 3600 32gb (8 x4)
2 Asus R9 290x's
Samsung 940 pro 500gb as the boot drive
Seasonic 1000 watt psu (older, but voltages seem to check out)
Did a fresh install of windows 10 and had stability issues. Up to this point I didn't even know what the windows 10 blue screen looked like. Ran the newest memtest (v 7.5?) and had 61 errors, all on test 13, the hammer test. Found a newer bios for my motherboard and updated it. There were supposed to be stability fixes and compatibility fixes with memory in it. Last I looked the currently running memtest had over 300 errors and it wasn't done before I left for work. The memory is on the approved vendors list for the motherboard. I'm running the xmp profile on it and double checked that the voltage and timings were set right. Am I missing something or is it time to RMA these sticks?
Any help is appreciated
8700k
2 Asus R9 290x's
