Saturn_V
- Sep 24, 2008
They had major issues rolling out the 4.0 upgrade over the recent holidays, (excessive wifi over-draining the battery) and mine had to be rolled back for a couple of weeks. Now at 4.01, works perfectly. And yes, there are cheaper smart thermostats out there, even your electric utility will give you a smart thermostat if you sign up for specific rate plans (usually based on peak usage hrs). But I'm still very happy with mine, just it's ability to turn itself off when I'm not at home is a huge deal.
I'll be honest, if the Nest was initially a Google or Apple product I never would've bought it.
