Rabid Sloth
- Feb 2, 2012
I believe that the AXP-140 is even larger than the Noctua and would also cover the PCI slot. A H60 or H20 620 could be the way to go otherwise I would say the Shuriken Rev. B is a good option.
Edit: I stand corrected. In looking if you orient the AXP-140 the right way it will leave the PCI slot availabe. I'm guessing you could probably do the same with the Noctua by turning the heat pipes toward the PCI slot.
