My Dell 3007WFP-HC dismally fails this Lagom LCD test. This is what it looks like, as seen from a distance of 3.14 meters:
The "lagom" is supposed to blend into the background everywhere. At the very least the pattern should be uniform.
I knew that this monitor was dimmer towards the edges, but I assumed it was a linear effect (like vignetting on a camera lens); I was fine with that. But gamma nonuniformity is much worse than mere brightness nonuniformity! An image should locally look identical no matter where it's displayed on the monitor. On this 3007WFP-HC the gamma is all over the map; it ranges from 2.29 (in the center of the blending blob) to 1.39 (at the lower-right corner), for the luminances used in that lagom test pattern.
Do other copies of the 3007WFP-HC have this problem? What about other 30" LCDs, especially the NEC 3090WQXi (both in native/uncalibrated, and calibrated + uniformity enabled), and how about the 27" iMac?
