D
Deleted member 89018
Guest
I have previously tried the silverston sfx 450w modular psu but it was too noisy. So I reverted back to a 5yr old Seasonice 550w non-modular psu (allows me to use my gtx570). The AX850 is obviously overkill but it's very silent so I just wanted to use what I already owned.
What CPU cooler are you using btw?
Ah, yeah, I can understand that. I actually bought the SG05 with the included non-modular PSU specifically because of reports of noise with the modular one. Cable routing wasn't as annoying as I'd expected and it's really quite quiet.
I had been using a Zalman CNPS8900 originally, with an i5-4670k, but those wound up in another system. When I put the i7-4790k in here I swapped in a Xigmatek Janus. Works wonderfully, although one of the fans rattles occasionally - not sure which it is, but I'm guessing the 120mm. If it is and it keeps up I might replace it with a Prolimatech Vortex 12.
Zap said:The fan controller may be set on the more aggressive side to handle smaller cases with less airflow, but based on your description of fan speeds ramping up and temperatures maxing out at 72°C, it sounds completely normal to me.
Yeah, I've done a bit more reading of threads on other 970s and I'm thinking the same.
