RangerXML
- Apr 16, 2006
Pictures with handwritten date and handle:
Drop Alt
Halo True switches lubed with KEBO GPL 204. 1.2mm foam under PCB. Clip and lube the stabs, but I was unable to get rid of the rattle (ended up using Gateron Stabs and they worked great, but keeping those, recommended upgrade).
$230 shipped (within US).
Tada68 and KC21
Tada68 has VIA Firmware.
The Tada68 has the original plastic case, sticker bombed, there is scrap foam under PCB to reduce the hollow sound. Comes with Mod-M Tactile switches and PBT keycaps (dye-sub and cherry profile). KC21 has been sticker bombed to match the Tada68 and I'm selling them as a set. Uses Gateron Brown switches, I through on some generic keycaps, but normally I would use a matching set for both the Tada68 and the KC21, example: https://i.redd.it/uxosgwix18g51.jpg
$100 shipped (within US).
Corsair K63 Wireless
Stock Cherry MX Red switches, includes wireless receiver and original USB cable.
$80 shipped (within US)
Drop Alt
Tada68 and KC21
