mrgstiffler
- Dec 20, 2000
So you made the mistake of installing the programs to 'program files' folder. Make a new folder and install your stuff there, no shield.
There's nothing wrong with installing apps to Program Files. In fact, that's what you're supposed to do. Older apps were unaware of the ProgramData folder. Anything usable these days is aware and will put files where they need to be. You shouldn't get a UAC prompt after first run. If you are, the app is most likely old, crap or malware. There are very few apps that legitimately require escalated privileges.
