I spent a little time with the search function, but I was unable to locate anything that specifically addressed my question, so here we go.
I am upgrading the old watercooling setup (BI Pro II, eheim 1250, apogee on 3/8ID).
I have decided on a MCP655 pump, keeping the apogee, and probably going to 1/2 ID. Also, T-line, fillport and purgeport.
I am pretty much sold on the MCR-320-QP. My only problem is, which fans do I get. I'm looking for decent cooling, but I need as quiet as possible. I realise I will probably see 40s idle temps with this setup, and that doesn't bother me at all.
Yate Loons look good, and the new Scythe S-Flex D fans also look good. I will be running 6 in push/pull. These are going to be run through a rheostat for speed control. I guess basically, are the S-Flex fans worth the near 4x price premium over the Yate Loons? The Loons have a 20,000 hour rated life (2 years or so) while the S-Flex ones have a 150,000 hour rated life.
This will be cooling an E6600 or a Q6600 come May. Possibly also an 8800GTX. Case is a Lian Li PC-75. Intake will be 6x 80mm Panaflo L's, radiator will be top exhaust.
