angle_theory
- Mar 4, 2012
is this a replacement for the FS2333?
I was just about to pull the trigger on one of those...
No, this is a PC gaming oriented monitor while the Foris is meant for PC and console gaming.
The Eizo EV2336 uses the same light matte coating, has equally as good default colors, has less overshoot ghosting than the FS2333, does not use http://www.tftcentral.co.uk/articles/content/pulse_width_modulation.htm#side_effects unless the brightness is set below 20% and has a height adjustable stand.
just like various TN differs in their viewing angle performance VA differs tooDon't worry. I don't know what crack was flatpanels guy smoking when he wrote about bad angles but VA are much better then TNs and slightly worse than IPS in that regard.
So they are going to continue to manufacture / market this alongside the FS2333?
I know they don't overlap entirely, but they are pretty close.
The FS has slightly less input lag (?) and an extra HDMI port
The FG is .5" larger, less eyestrain, and better black levels. (and of course less motion blur but I'm not sure how this will affect console gaming)
Weird thing is that the 120hz panels aren't listed on AUO homepage anymore, and if both are correctly marked as discontinued from the links I have provided, then what panel is Eizo using?
Why do you think that the FG2421 would be unsuitable for console gaming? Does the VA panel have worse viewing angles?No, this is a PC gaming oriented monitor while the Foris is meant for PC and console gaming.
It's a Sharp MVA panel according to TFTCentral. Note that it's 23.5" diagonal and not 24". Sharp have one listed on their website, although spec and details coming soon apparently:
www.sharpsma.com/lcd-suite
Just as good motion clarity or maybe even better since Eizo is quoting ≤ 1ms backlight strobing. Versus the current crop of 120+Hz TN in Lightboost mode monitors the Eizo has around ten times the contrast, far superior blacks, colors, viewing angles and AR film. Vastly superior.
WOW, this changes everything. I had it narrowed down to one of the TN/120hz vendors, either BenQ or Asus, as a second monitor for gaming. (I have the below listed IPS Dell ).
Looking at the preliminary comments about the upcoming BenQ XL2720Z, do you think at this point the Eizo has the edge even over this one as well?
Dumb question, since it may be in the reviews (and yes, I read them). Is the strobe available for framerates below 120hz? Can I do it on 60? Reason I ask is that my computer hardware can't hope to pull a constant 120, and I'd rather have consistency versus frames.
Framerate =/= Hz.
You can still run this monitor at 120Hz with strobing for improved motion clarity even when your PC is only getting 30-60fps in-game.
Hi Guys, got my fg2421 today and I disassembled it.
Now you can see the panel is made from SHARP. According to the database, this panel is a true 10-bit panel but the color depth is limited by EIZO IMO, because I guess EIZO also has its high end product lines which use this panel with better driver will surely charge more money.
Hope this helps.
SLAYER! Please take tons of photos of the chassis bezels and the panel/electronics chassis front and back please and post them! Me love you long time..
Hn, I don't know if I should cancel my Amazon order and go with BLT or what. I hate that Amazon is so erratic and you don't know when anything will ship.
Placed an order on shopblt. Will cancel whichever one does not ship. I remember amazon took a long time to get the FS2333 in stock.
Dear Phillip:
Thank you very much for your order:
Sold To:
<snip>
Ship To:
<snip>
Account Number: <snip>
The following item you ordered is in stock:
Item Unit Extended
Qty ID # Description Price Price
001 BTJ6828 23.5IN WIDESCREEN LCD 604.11 604.11
1920X1080 5000:1 240HZ
400CD / M2
MFG #: FG2421-BK
SHIP: FEDEX
Purchase Sub Total: $604.11
Shipping: 0.00
Handling: 0.00
Sales Tax: 0.00
Order Total: $604.11
We have processed this item for an estimated ship date of today. The day following shipment, a receipt will be sent by email with tracking information.
If you should have any questions or concerns, please do not hesitate to contact us via the methods listed below. Thank you for your time, and business.
Best Regards,
Stephanie L.
maybe a dumb question, but please educate me does such a high contrast ratio really make a difference? Would you see the difference compared for example to a 2500/3000:1 monitor?
What the heck is going on with Amazon?
But $50 more. Amazon is screwy sometimes.
Who knows. I'm impatient though so I swapped my order to ShopBLT - 18 left! At least the shipping was free. Maybe you could order one of your three from there and see which comes first
Sad, isn't it? They could make one you describe in two years.ho hum, still dreaming of something like this but 28.5", 4K, no lag, g-sync, 8 bit, no banding, VESA mounts. It's probably not going to happen in my lifetime
