Without the need of high performance memory, OCZ have some ok prices on DDR3 memory.
If for some reason dual kit (OCZ3P1333LV4GK) is cheaper per memory module than tri-channel kit (OCZ3P1333LV6GK). If I want to populate six slots (12GB) I would prefer to buy 3 dual kits instead of 2 trio-kits but I would like to confirm.
1. Can some one around here confirm that both kits (for the models above) contain the same memory modules?
2. If for budget constrains, can I buy only 2 dual kits and total 8GB and run one channel of an x58 motherboard with only 2GB? Any performance, compatibilty issues?
Thank you.
Thank you.
