blackbeaSSt
- Oct 22, 2012
Delete
Basically I have 2 Intel compute sticks plugged into 2 different TV’s. These run marketing material 24/7 and are only touched by those of us in IT. Ever since we installed them then have rebooted periodically which takes it back to the login. Our customer isn’t happy with that and I’m trying to figure out what could be causing it.
Ive done the typical disable windows updates, but other than that what else could be promoting a reboot? To the best of our knowledge there is no power issues as nothing else seems to be having issues.
Event viewer just shows a lot of “distributedCOM” warnings about the machine-default permission settings do not grant Local Activation permission for the COM server.....
The only errors are AppModel-Runtime and Kernel-EventTracing.
Anything else I can look at to try and pinpoint the reboots?
You can do that with linux easily and it will never boot up the stick unless you tell it to.Well to be honest it’s nothing major that we’re running for this marketing project. It’s basically a slideshow of pics on a loop.
And I agree that a Windows related system wasn’t the best, but I was told we needed something to be able to remote in to remotely and maintain.
Why haven't you configured the system to autostart the presentation on reboot?Yeah that would render us not being able to remote into it. So that’s not really an option.
What app are you using for the display?I’ll have to look into that. Can Windows bypass the non password option for the ”user”, open the app along with the files, and make them fullscreen?
