Adreneline
- Sep 16, 2008
I just got the X3 720 a couple weeks ago along with a CM690 case and MA790X-UD4P mobo (Gigabyte). Rest of specs are in my sig.
My CPU temp usually idles around 39-41 on idle and 43+ on load, and right now it's sitting at 43 on idle... just turned my comp on.
My GFX temp is 49, a little abnormal too since its usually around 44-46.
But anyway my CPU temp has always been around 39+, and a lot of reviews for the 720 said their CPU's idle around 22-25. That's 20 less than mine!
One idea I thought was that I mixed up a few AMD processors when seeing if my processor was faulty, and so I had to wipe off (some) of the thermal paste to see the model number, but this couldn't make it go up 20 in temp can it? I'm using the stock CPU fan, which I know some people have used when saying their 720's idle around 22ish.
Thanks.
Thanks.
