Hey, so I'm looking into getting a new cpu (and therefore also mobo), so I'm trying to figure out what I should be looking for (good chance I will buy it used) and how much money I should scrape together. Relevant questions from the sticky:
1) What will you be doing with this PC?
Some CPU intensive games (csgo, minecraft), basic video editing in Sony Vegas
3) Which country do you live in?
Estonia
4) What exact parts do you need for that budget?
Central processing unit, motherboard
5) If reusing any parts, what parts will you be reusing?
GPU: Sapphire HD 7770
PSU: Corsair CX500
Case: Corsair 200R
RAM: 8gb Crucial Ballistix Sport (single stick)
6) Will you be overclocking?
No experience, so I'd rather not - but if it means a much cheaper setup for the same performance, I can look into it
From weeks to months, depends really
9) What features do you need in a motherboard?
USB 3.0 and Sata 6gb/s would be nice, don't know what else to ask for really. Doubt I'll need a dual GPU setup.
Mainly concerned with the mobo right now, since I'll prolly buy the CPU at a later date and prolly used. Am I right that I should be looking for H77, B75, or Z77 mobos? mATX seems cheaper, so if it doesn't change performance, that would be a smarter choice, yes?
This is the cheapest acceptable one I can find:
ASUS P8B75-M LE / Intel B75 / 2 x DIMM, Max. 16 GB, DDR3 Non-ECC
Full list of available mobos (chipset can be filtered on the left): http://www.hinnavaatlus.ee/products/Arvutiriistvara/Emaplaadid/
CPUs are here: http://www.hinnavaatlus.ee/products/Arvutiriistvara/Protsessorid/
Estonia
PSU: Corsair CX500
Case: Corsair 200R
