I have a HTPC that I am getting back in running order, and I picked up a MSI 8500GT card that has no fan, and also has an HDMI output on the back. In order to feed the audio to the HDMI, it either has you use a coax cable (my mobo does not have coax) or an internal SPDIF cable. My mobo is an Intel DG33TL, and I am having trouble figuring out which two pins to connect this cable to. According to the diagram with my mobo, under HD Audio Link, the pins are labeled:
Ground : No Connection
3.3V STBY : No Connection
Key (no pin) : SDI1
+12V : SDI0
3.3 Vcc : SD0
Ground : SYNC
3.3 Vcc : RST#
Ground : BCLK
Does anyone have any idea based on those labels which two pins need to be connected for me to get audio to my HDMI connector? Thanks very much
Key (no pin) : SDI1
+12V : SDI0
3.3 Vcc : SD0
Ground : SYNC
3.3 Vcc : RST#
Ground : BCLK
