This is my first flat panel monitor and I hooked it up using the DVI cable to my 6800GT. Now the screen is a little off center and its off to the right a litte and the right scroll bar ends up at the left of my screen.
How do you center the screen while using the DVI cable hookup? I know you can manually center the screen when using the old VGA cable but this is a upgrade
