I'm a fan of quieter computing, so I love putting high density foam sheeting in my computer to help cut down on echo and sound transmission. Only problem is that I'm upgrading now (full size) and would like to find a case that would fit 1/2" or more of foam on all the panels (behind motherboard tray, etc). It seems that every case seems to follow roughly the same dimensions and cage/tray placements.
Any suggested cases with lots of room for sound proofing?
