Case for budget price
alfniro
Hello,
I'm hesitating for the choice of a new case, budget between 65-85 CHF (or à its the same...)
MSI MAG Forge 100R
FRACTAL DESIGN Pop Air
Corsair 4000d airflow
Be quiet pure base 500
Asus TUF Gaming GT301
or FRACTAL DESIGN Focus G for front-mounted optical drive.
my future config:
https://pcpartpicker.com/user/alfniro/saved/Pc8Lyc
I'm not looking for bling bling, but a mid-tower case with efficient air cooling.
Thanks for your advice!
I would pay a little more then and get a better NVMe drive like the WD SN850x which is $65 for 1tb. The P3 doesn't have dram and kind of a turd for a system drive. Get the Focus G if the disc drive is important too you. Can't go wrong with the 4000D, pop air or be quite other wise.
Hello,
MSI MAG Forge 100R
my future config:
What's the goal of this system? Just gaming?
Gaming: rdr 2, some fps (battlefield or cod), cyberpunk?
Flight simulator 2020
Unreal engine: i will try to create some virtual architecture and some Little open world or so
All in 1080p for sure, but maybe try à little 1440p?
