Can I cram it?
flegg
I'm getting an HD 4870 1gb and putting the artic twin turbo on it.
Eventually I may want to double up on this and crossfire.
Will 2 hd 4870's with artic twin turbos fit on either a P5Q-Pro or EP45-UD3P? Inside an antec 300 with 2 HDs in it?
Just need one pci slot to survive
It fit with a Rampage Formula. That's all I can add. Info:
http://hardforum.com/showthread.php?t=1338083&page=2
Pictures are on my photobucket if you check out that thread and don't trust words alone. :p
I must add though, the setup might be too hot to overclock the cards by much. While the bottom card stayed icy cool, the top card idled like 20*C warmer as it took in the heat from the bottom card. Gaming was fine despite the overclock and temps.
