relapse808
- Apr 11, 2005
I am going to be mirroring a server for work for replacement before going onsite. I have a script that works well but its without the vss writer causing issues with profile paths as well as some locked file. Here is the script I have now
D:
Cd \
Net use Y: \\XXXX-fp01\d$
Net use Z: \\XXXX-fp01\e$
For /f "eol=# tokens=1,2," %%a in (d:\folders.txt) do robocopy %%a:\%%b .\%%b /MIR /v /r:0 /w:0 /copyall /log:d:\robolog-%%b.txt
the XXXX in the server name is where I would put the first part of the server name as we have a 4 digit site code for each server in our wan. The folders.txt would look like this and the folders needed are split on two physical drives
Y APPS
Y USERS
Z DATA
Z Profiles
I am now trying to add the vss writer on top of this as explained here :
http://ithelp.cveg.uark.edu/IT_Help/Documents_files/backup.pdf
I am trying to figure out how I can still map the two physical drives and still have it perform the loop to copy all four directories with the VSS writer. If it was a single drive and didnt need the loop I think I could do it but I am lost at this point. Please help.
D:
Cd \
Y APPS
Y USERS
Z DATA
Z Profiles
