Best glossy IPS monitor ATM - Dell S2340T, LG ET 83 or Acer T23HL?
Frameless
Im still using the Dell ST2220T after the failure that was glossy Dell S2340L that had horrible picture noise, screen door effect and ghosting overshooting.
What im wondering about, is if the new Dell S2340T, Acer T23HL and LG ET83 has the same bad traits as the Dell S2340L? Do they all share the same panel?
I want to buy and test one of the screens, but there is very little information out for me to make an informed choice. If they all have the same bad traits as the Dell S2340L i wont even bother with them. Any other information about screen coating (i see the Acer T232HL has some kind of anti-glare even though its glossy), input lag and color measurement would be great too.
UPDATE: Found reviews on prad.de of the Dell S2340T and Acer T23HL. Both screens have horrible color measurement, needs calibration. Input lag is extremely low on both screens. Go here for tranlation: http://www.microsofttranslator.com/bv.aspx?from=&to=en&a=http%3A%2F%2Fwww.prad.de%2Fnew%2Fmonitore%2Ftestberichte.html
