michalrz
- Jun 4, 2012
It's actually verbatim
Polypropylene (sorta like hard rubber) injected into a mold.
Rubber suspension of the membrane within its housing. Probably glued to the membrane.
Not one, not zero, but two magnets.
I think this is done due to space constraints but I might be wrong as there are dual coil-dual magnet drivers, or so I see in a patent online.
I think you've set them up a bit wrong though, in the corner of the room they would probably sound better facing slightly outwards (open angle) instead of this dual focusing action goin' on
Directly from the spec sheet:
5 1/4 (133mm)
Injection Molded Clay/Ceramic
Reinforced Polypropylene Cone
Rubber Surround
Dual Magnet
I have no idea what all that means, but the sound is sublime.
