OlIv0rIolI
- Dec 2, 2005
I am planning on upgrading to apogee xt and install it into the ft02 case. I am aware that the xt has to be oriented in a certain way with respect to the motherboard cpu socket. Correct me if I am wrong, but I believe the outlet port has to be the highest point to account for gravity so water rises after cooling all the copper parts.
The motherboard orientation in the ft02 is oriented 90 degrees clockwise with respect to normal configuration. So should I install the xt offset 90 degrees counter-clockwise so that the outlet port is still at the highest point with respect to the ground?
http://www.newegg.com/Product/Produ...cm_re=silverstone_ft02-_-11-163-161-_-Product
