eighteen_psi
- Jan 28, 2002
Got an Audiophile 2496 under 2003, configured as workstation.
Love the OS...so much faster disk access than XP Pro (especially the SCSIs).
Anyway..only one piece of hardware drama to sort out, and its a big one. My M-Audio drivers work (officially not supported..need to run the installer in compatibility mode for XP) but I cannot get any application to output to the device. It shows up and all but it won't output. I'm currently using the onboard AC97, piped through the M's I/O & Hardware mixer, and back out to my amp/monitors/sub which sounds passable, if not audiophile grade. The problem is the horrid latency. Editing in premiere is nearly impossible with the half-second lag every time i jog/scrub a frame. Sound work in nuendo is a laughable proposition.
Point is I need my M card working....and I have no idea how to get it there. Does anyone use ASIO cards/apps under 2003? If the OS doesn't support it, which it may not, i don't know...it almost has to be possible to enable it with some files from my xp pro disk I'd think.
