three4seven
- Oct 11, 2004
I'm trying to run three 30" LCDs on one 6950 1gb (not for gaming) that use dual link DVI inputs.
I ended up buying two Apple miniDP to dual link DVI adapters and used the native dual link DVI connection to connect the three monitors.
Here's my issue - no matter what I do - I can only get two monitors to work at once.
I've tried every combination to test if it was an issue with the mini DP adapters.. or my monitor... or cables... or my 6950. Everything seems fine independently from what I can tell. The only thing I've come up with is that I cannot use both mini DP to dual link DVI cables at the same time. It only works if I use one Dual link DVI (native) and one miniDP.
When I add the second miniDP adapter, all the monitors aren't detected correctly - can't use native resolution and become detected as "mobile PC displays'.
I tried hooking it up to another system with 6950 2gb setup - and the same issue occurred. However, if I kept hitting "detect" (in windows 7 "screen resolution"), it would eventually run all three monitors at native resolution. Upon restarting however, I would have to go through all of it again to get it to work. Tried the same method and can't get it to work on the 6950 1gb - even using the "detect" method.
Just seeing if anyone has any experience with two apple miniDP adapters simultaenously and if they experienced the same issues.
Update: Seems I can get it to work by using the detect method to get two miniDP to work at the same time without the native dual link dvi plugged in..
Second observation: I was finally able to get all three screens to work by plugging both USB connectors into an external USB charging hub that powers on the two USB cables from the adapters at the same time.
That said, it doesn't restart properly. As soon as you shut down, you have to go through the whole process again - unplugging the USB power cables from the miniDP and then back into the usb charger... and they must power on at the same time....
