Just curious if all the top tier have gone to the bottom mount orientation.
I still have a original Antec solo case, top mount I'd like to use for a build.
My V1 Corsair HX650 is top mount but I believe the V2 is not.
I suspect all the latest Corsair and Seasonic versions are designed for bottom mounting.
You can use a bottom for top, just the cables would have to go to the floor then go up so the sata connectors are correct.
