I didn't know where to put this, so here it is.
I have a car ECU that has gone bad. Problem is, it's VIN coded, so I can't exactly plop down an ebay ECU and have it start the car.
Soooo, the chip that's holding the VIN/immobilizer info is a four sided SMC. In theory, it should be possible to buy an ebay ECU, swap the chip holding the car VIN/immobilizer info on the PCB and have it start the car.
The chip in question looks vaguely like this. It doesn't quite have so many pins like the 100+ SMC, but not that few either.
I have access to a basic soldering kit and a heatgun, if that helps.
I've looked at various tutorials for desoldering and soldering SMC, but most of those were for SMC that had two sides. I'm aware that the principle for soldering for four sided SMC is exactly the same as two sides, but I'm not sure how to go about it.
Do I just apply solder to one side in one giant wave, then use a wick to remove all solder bridges?
