Is this better than these chips from the recent deal, for a Z68 chipset?:
G.SKILL Ripjaws X Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL8D-8GBXM
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231445
Z68/P67 doesn't have an affect on ram.
The same stuff, different heatsink color.
This one is at the same price too, and comes with a 2GB flash drive.
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231460
G.Skill Sniper 2x4GB 1866.
Great deals.
I'm confused what you mean...
8GB Gskill RipJaws X DDR3 1866
timings: 9-10-9-28
Is the ram posted in this deal.
While the other is:
G.SKILL Ripjaws X Series 8GB DDR3 1600
timings: 8-8-8-24
The rated speeds are different. The timings are different. Not really the same stuff.... unless its a known fact that its very easy to get those same speeds with increased timings of the second one.
Does this memory work with the i7 920 and X58 board?
Didn't see the different speeds, but they will work. I tried memory OC to 1866 many times with my 1600 ram, the system doesn't post.
Better off buying the fastest ram for your money than attempting to OC.
so are you saying the blue pill or the red pill is better?
anyone know how tall the ram modules are with the heatsink? Trying to get something half of the height of the Corsair Vegance ram.
