I'm looking to get the best gaming PC for roughly 800-1000 bones.
So far I'm going with the e8400 + Asus P5Q combo deal at Newegg. I added a NVDA 260 in there since that is where I need to be with a 24 inch monitor. I plan to install Vista Ultimate and re-use my current optical drive.
I'm a bit stumped on the power supply and case. I like those modular PSUs but I'm not sure if they are in the budget and I do need something powerful enough for the 260. I also need a suggestion on a cheap case that the GPU can fit in. Quiet is also a plus!
I'm at $654 - 65 on rebates so around $589 so far..
Thanks for any suggestions!
