matrix563
- Sep 1, 2006
you can use the 6950 bios after unlocking and keep all the shaders running?
Last night I ordered 1 MSI and 1 HIS 6950 and I'll update the thread with my findings, hopefully I'll add to the my 6950s unlocked successfully. I picked those 2 models specifically as they both have 0 failed unlocks in this thread and in another thread from another forum. Here's hoping that trend continues
Dear God, its a cold day in hell indeed.
My advice is to do a full reformat to purge your Nvidia drivers before installing the 10.12a's. I had random CTD's and issues that this likely would have avoided, in the end I went back to 470's for folding. The 69xx cards have a ton of potential though and I was very impressed with the hardware, its just the drivers that still feel a bit finicky.
So let me get this all straight... I've always been a little confused on what makes a graphics card model superior to another, as in does the company spend the same amount of money to make a lower and higher end model but the lower end model just has settings turned down?
Because from this thread it seems these companies spend the same money to make the 6970 as the 6970, but they just disable some features and sell the 6950 for less? So essentially the difference in sale price for the 6950 and 6970 is pure profit?
Yes its called binning and Hardware manufacturers have been doing it for decades. Basically its about hitting the supply vs. demand curve. It costs to much to design all of these cards separately to hit each purchasing segment. More people will buy a $300 card over a $400, and it costs less to design the $400 card and cut it feature wise down then it does to design a $300 card that has to be handpicked to run a the $400 cards performance. Not only that but its harder to keep performance people from buying the $300 dollar card and running it at $400 if clock speeds are the only difference. It also allows for less waste, a GPU core that has a block of streams that won't hit spec can have those streams disabled and sold as the $300 card. That's where the 10% fail comes in.
That 10% is way above par as well, AMD/ATi is getting excellent yields on the 6970.
Hopefully you purchased the apple adapters
I didn't, but I read a bunch of reviews before I purchased and the ones I ordered from monoprice are just as good.
Don't hate on AMD or displayport when your adapters show up and dont support 120hz.
Posted via [H] Mobile Device
Warning this image may cause heart attacks and bring about the Apocalypse. The 4 horsemen are headed to the realm of earth as I type this and hell froze over. I expect those kinds of jokes. LOL
Here it is, my build still boxed, will be building tonight probably
Still waiting for my mini DP to dual link dvi active adapters.
Uploaded with ImageShack.us
Usually I'd be jealous but when I saw it was yours I was stoked! You deserve it for all you contribute to the forums! Those graphics cards are sick I definitely think you made the right choice
Lol 1500W PSU. Just lol.
Lol. Only thing I'd ever advocate a 1500W PSU for is an overclocked 3xGTX580 setup. For everything less a Corsair AX 1200W will be ample.
with the way PSUs are going maybe he is future proofing
Three HD6950s and an overclocked 130W CPU is still only around 700-750W out of the unit, max, unless you flash all the cards to 6970s, in which case maybe 850-900W. Either way, a long way from 1500!
Unlocked a sapphire 6950 successfully. Hope someone comes up with one application to overclock it, set a fan profile, and adjust voltages if needed.
Look at MSI Afterburner.
AFAIK Afterburner can't adjust voltages on 6950->6970 cards. I'd be happy to find out otherwise though Perhaps flashing with an Asus bios will let you use their smartdoctor or whatever to change voltages. I haven't tried anything like that yet.
For the record, got a Gigabyte 6950 and flashed to 6970, running at 925/1450 stable.
don;t they say you get the most out of a PSU at 50% load?
