Sounds like it is dying. RMA it if under warranty, bake it if not.
Do you hear a repeating noise and does it freeze, or is this on all the time? I got this on my first 5770, bought a second and it still happened. Kept the CPU at stock clocks and they've been working fine. It seems my motherboard or (more unlikely) my cpu was the source of the problem.
That said, my card outputs worked fine the whole time and this only happened occasionally.
Both DVI do not work, And when i remove the gpu and hook the monitor to the onboard video it works fine.
