Well it's been a long time since I am looking into getting a monitor that suits more than one purpose but I have finally given up. I wanted a nice 32" 4K with Adobe RGB, great uniformity and maybe at least 75Hz that also don't suck for games (casual) and could also maybe support HDR.
Anyway the above thing does not exist or what comes close for the professional features still costs over $2,000 and is not perfect (Asus PA32UC) or you need to go for an Eizo/Nec that cost $3.5K or more...
So I decided that I will go for a 2 screen solution to make things easier. I already use a secondary 24" 1080p monitor (Samsung IPS) so I was thinking of replacing this with something suitable for color proofing prints so I need AdobeRGB. I have narrowed it down to the following choices.
First of all I am really torn between 24" or 27" and that depends on what brand I choose to since pricing differs. The prices below are off Amazon.de and are for reference since they can be found a bit cheaper elsewhere. I also buy without VAT so its minus 19%.
Eizo ColorEdge CS2420 24" 1920X1200 - EUR 629
Dell UP2716D - 27" 2560X1440 - EUR 620
Benq SW2700PT 27" 2560X1440 - EUR 678
With these I stay in the 650 Euros range and the only decision to be made falls into larger vs higher quality category and the most important thing here is Panel Uniformity. In other words and after research going with the EIZO is my best bet for great uniformity. On the other hand going with the BenQ I might be lucky, get a good panel and end up with more monitor for the money. The Dell worries me since it is older and browsing through Dell's forum I read some angry comments along with some negatives in several reviews - it is the best looking style those wise on my desk (you can see it)
Eizo ColorEdge CS2730 27" 2560X1440 - EUR 1029
BenQ SW271 27" 3840X2160 - EUR 1198
NEC Multisync PA272W 27" 2560X1440 - EUR 1024
Selecting any of these requires more spending and some would argue that I can get a 32" 4K model for less. However, I need Adobe RGB and this will be a SECONDARY monitor used for color proofing. I will get a 32" or larger 4K display to be used as my primary monitor next year when the new models come out. One thing at a time.
So the dilemma here is whether I should go for a 2560X1440 display from NEC or Eizo with great panel uniformity or play the lottery and get the BenQ that is 4K and use it with 200% scaling.
Now if I go for the BenQ I am approaching a price point that makes me wonder whether I should go for the higher end model the BenQ SW320 which is a 32" model and costs 1400 Euros which is only 200 Euros more. It does look to me like a waste of 1200 Euros if not getting the 32" model but then it all becomes a vicious circle (NEC or EIZO 27" very close to the BenQ 27" 4K and so on).
________________________________________________________________________________________________
What would you do?
What would you do?
